Errors when creating a calendar event discard your work
  • No replies
Hi, I've encountered a problem where if any error occurs when you try to create a new calendar event (I.e. Thunderbird cannot connect to the CalDav server), it will give you an error pop-up and discard everything you have input.
Losing work like this is extremely annoying and I think what should happen when an error occurs is that Thunderbird would go back to the event creation popup, preserving everything that was input into it, and let you try to create the event again (perhaps save it into a different calendar).
I'm not sure if this is the best place to ask about this but it was the most easily accessible place I could find.
This happened in Thunderbird desktop version 138.
Hi, I've encountered a problem where if any error occurs when you try to create a new calendar event (I.e. Thunderbird cannot connect to the CalDav server), it will give you an error pop-up and discard everything you have input. Losing work like this is extremely annoying and I think what should happen when an error occurs is that Thunderbird would go back to the event creation popup, preserving everything that was input into it, and let you try to create the event again (perhaps save it into a different calendar). I'm not sure if this is the best place to ask about this but it was the most easily accessible place I could find. This happened in Thunderbird desktop version 138.
